Disassembling Canon Powershot SD880 LCD Display
  1. Disassembling Canon Powershot SD880 LCD Display, Back Cover: step 1, image 1 of 3 Disassembling Canon Powershot SD880 LCD Display, Back Cover: step 1, image 2 of 3 Disassembling Canon Powershot SD880 LCD Display, Back Cover: step 1, image 3 of 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 LCD Display, LCD Display: step 2, image 1 of 3 Disassembling Canon Powershot SD880 LCD Display, LCD Display: step 2, image 2 of 3 Disassembling Canon Powershot SD880 LCD Display, LCD Display: step 2, image 3 of 3
    • Remove the screws(2.88mm) at the top right corner and bottom left corner of the LCD screen.
    • Disconnect the ribbons connecting the screen to the camera.
    • Remove the screen by lifting it off.
Ben Tupas
317 Reputation
3 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 2,314
