How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera
  1. How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera, The plastic housing: step 1, image 1 of 3 How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera, The plastic housing: step 1, image 2 of 3 How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera, The plastic housing: step 1, image 3 of 3
    • Using a Tri-Wing screwdriver #0, remove the screws from the sides of the camera.
    • There are two on each side, and two on the bottom plate.
  2. How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera: step 2, image 1 of 2 How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera: step 2, image 2 of 2
    • Gently grip and remove the side cover while holding the Mini-USB cover open.
  3. How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera: step 3, image 1 of 3 How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera: step 3, image 2 of 3 How to disassemble the Cover Plates of the Canon Powershot SD790 IS Digital Camera: step 3, image 3 of 3
    • Grip the camera from the sides and carefully remove the screen cover. Start at the bottom edge and slowly lift up the cover. Pay special attention to the area with the camera/video switch.
    • While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off.
Stanley
372 Reputation
4 Guides authored
Cal Poly, Team 4-33, Regan Winter 2011 Member of Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 5,306
