Canon PowerShot SX600 HS Display Screen Replacement
  1. Canon PowerShot SX600 HS Display Screen Replacement, Battery: step 1, image 1 of 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Display Screen Replacement: step 2, image 1 of 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Display Screen Replacement: step 3, image 1 of 2 Canon PowerShot SX600 HS Display Screen Replacement: step 3, image 2 of 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Display Screen Replacement, Power and Shutter Buttons: step 4, image 1 of 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Display Screen Replacement: step 5, image 1 of 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Display Screen Replacement: step 6, image 1 of 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Display Screen Replacement: step 7, image 1 of 2 Canon PowerShot SX600 HS Display Screen Replacement: step 7, image 2 of 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Display Screen Replacement: step 8, image 1 of 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: step 9, image 1 of 2 Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: step 9, image 2 of 2
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Display Screen Replacement: step 10, image 1 of 1
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Display Screen Replacement: step 11, image 1 of 1
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Display Screen Replacement: step 12, image 1 of 1
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Display Screen Replacement: step 13, image 1 of 1
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
Jennyfer Munoz
411 Reputation
3 Guides authored
USF Tampa, Team S6-G4, Lacy Spring 2017 Member of USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Members
9 Guides authored
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 21
All Time: 4,509
