Introduction
Canon PowerShot SX600 HS camera, can have a broken or damaged screen/LCD. The screen can be noted to have cracks or the LCD does not allow the screen to display, either or calls for a replacement of the display screen. Use this guide when replacing the display screen or LCD for your camera.
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
Lift the LCD screen ZIF connector tab and remove the ribbon cable.
Detach the no-fuss connector.
Lift the screen from its holder.
