Canon PowerShot SX50 HS Flash Bulb Replacement
  1. Canon PowerShot SX50 HS Flash Bulb Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Flash Bulb Replacement: step 2, image 1 of 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Flash Bulb Replacement, Flash Bulb: step 3, image 1 of 1
    • Lift up the flash as you would when using and activating the flash.
  4. Canon PowerShot SX50 HS Flash Bulb Replacement: step 4, image 1 of 2 Canon PowerShot SX50 HS Flash Bulb Replacement: step 4, image 2 of 2
    • Remove the two Phillips #000 screws, length 3 mm, on both sides of the flash.
  5. Canon PowerShot SX50 HS Flash Bulb Replacement: step 5, image 1 of 1
    • Pull off the back encasement of the flash with your fingers. The internals will now become visible.
  6. Canon PowerShot SX50 HS Flash Bulb Replacement: step 6, image 1 of 2 Canon PowerShot SX50 HS Flash Bulb Replacement: step 6, image 2 of 2
    • Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
    • See the guide on this link for soldering and desoldering.
  7. Canon PowerShot SX50 HS Flash Bulb Replacement: step 7, image 1 of 3 Canon PowerShot SX50 HS Flash Bulb Replacement: step 7, image 2 of 3 Canon PowerShot SX50 HS Flash Bulb Replacement: step 7, image 3 of 3
    • Once the wires have been desoldered, pull the flash out of its casing.
    • Remove one end of the rubber band holding the bulb in place.
    • Slide the bulb out of the flash.
  8. Canon PowerShot SX50 HS Flash Bulb Replacement: step 8, image 1 of 2 Canon PowerShot SX50 HS Flash Bulb Replacement: step 8, image 2 of 2
    • Completely remove the rubber band from the flash bulb.
Daniel Gurrola
267 Reputation
2 Guides authored
Cal Poly, Team 12-7, Lancaster Spring 2015 Member of Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 5,625
