Introduction
Replace the flash of the Canon PowerShot SX50 HS.
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
Now remove the battery pack from the camera with your fingers.
Pull off the back encasement of the flash with your fingers. The internals will now become visible.
Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
See the guide on this link for soldering and desoldering.
Once the wires have been desoldered, pull the flash out of its casing.
Remove one end of the rubber band holding the bulb in place.
Slide the bulb out of the flash.
