Canon PowerShot SX120 IS Back Cover Replacement
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Turn the camera to the side that has the screen. Unnscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: step 2, image 1 of 1
    • Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: step 3, image 1 of 3 Canon PowerShot SX120 IS Back Cover Replacement: step 3, image 2 of 3 Canon PowerShot SX120 IS Back Cover Replacement: step 3, image 3 of 3
    • Put the camera with the lens facing up, turn it to the side where the Cover battery is located.
  4. Canon PowerShot SX120 IS Back Cover Replacement: step 4, image 1 of 2 Canon PowerShot SX120 IS Back Cover Replacement: step 4, image 2 of 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: step 5, image 1 of 1
    • Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: step 6, image 1 of 3 Canon PowerShot SX120 IS Back Cover Replacement: step 6, image 2 of 3 Canon PowerShot SX120 IS Back Cover Replacement: step 6, image 3 of 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully make pressure downwards on the opening tool so the cover can gradually open.
    • Keep making pressure and slowly slide the opening tool through all the gap.
    • There is one point when the cover will disassemble completely.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: step 7, image 1 of 1
    • This is a final picture of how it's going to look when you disassemble the back cover.
    • You will have 3 parts:
    • 1. The camera
    • 2. The DC IN A/V OUT DIGITAL Cover
    • 3. The back cover.
Maria
887 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,724
