Introduction
Disassemble the back cover in order to open the camera and access the inside components.
Turn the camera to the side that has the screen. Unnscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
Put the camera with the lens facing up, turn it to the side where the Cover battery is located.
Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
Open the DC IN A/V OUT DIGITAL cover.
Turn the camera with the lens facing down.
Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
Keep making pressure and slowly slide the opening tool through all the gap.
There is one point when the cover will disassemble completely.
This is a final picture of how it's going to look when you disassemble the back cover.
You will have 3 parts:
1. The camera
2. The DC IN A/V OUT DIGITAL Cover
3. The back cover.
