Pull the back panel away from the camera body, starting at the end with the function buttons.
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Push the metal frame away from the metal tab using the spudger, to detach the frame.
Rotate the metal frame upwards.
Carefully lift the metal frame from the camera.
Remove the black LCD screen, leaving the thin lens pieces in place.
Carefully pull on the orange connector ribbon to disconnect the LCD screen.
The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
