Canon PowerShot SD1000 LCD Screen Replacement
  1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: step 1, image 2 of 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 LCD Screen Replacement: step 2, image 1 of 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 LCD Screen Replacement: step 4, image 1 of 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: step 6, image 1 of 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 LCD Screen Replacement: step 7, image 1 of 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: step 8, image 1 of 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 LCD Screen Replacement: step 9, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement: step 9, image 2 of 2
    • Pull up the metal frame surrounding LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 LCD Screen Replacement: step 10, image 1 of 1
    • Push the metal frame away from the metal tab using the spudger, to detach the frame.
    • Rotate the metal frame upwards.
    • Note: The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 LCD Screen Replacement: step 11, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement: step 11, image 2 of 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • Note: BE CAREFUL, both components are attached by an orange connector ribbon and cannot be removed yet!
  12. Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 1 of 3 Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 2 of 3 Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 3 of 3
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Note: Tweezers are helpful to disconnect the ribbon
Phillip Phung
651 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 50
All Time: 3,551
