Pull the back panel away from the camera body, starting at the end with the function buttons.
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Push the metal frame away from the metal tab using the spudger to detach the frame.
Rotate the metal frame upwards.
Carefully lift the metal frame from the camera.
Remove the black LCD screen, leaving the thin lens pieces in place.
Remove the metal frame on the side closest to the flash mechanism. This will expose the screw securing the flash assembly.
Use the spudger to carefully disconnect the flash assembly ribbon from the black connector lock.
