CHUWI GemiBook XPro Screen Replacement
    1. CHUWI GemiBook XPro Screen Replacement, Battery: step 1, image 1 of 2 CHUWI GemiBook XPro Screen Replacement, Battery: step 1, image 2 of 2
      • Peel off the black tape on the upper-right side of the motherboard.
      Ask FixBot
    2. CHUWI GemiBook XPro Screen Replacement: step 2, image 1 of 2 CHUWI GemiBook XPro Screen Replacement: step 2, image 2 of 2
      • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
      Ask FixBot
    3. CHUWI GemiBook XPro Screen Replacement: step 3, image 1 of 3 CHUWI GemiBook XPro Screen Replacement: step 3, image 2 of 3 CHUWI GemiBook XPro Screen Replacement: step 3, image 3 of 3
      • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
      Ask FixBot
    4. CHUWI GemiBook XPro Screen Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
      Ask FixBot
    5. CHUWI GemiBook XPro Screen Replacement: step 5, image 1 of 3 CHUWI GemiBook XPro Screen Replacement: step 5, image 2 of 3 CHUWI GemiBook XPro Screen Replacement: step 5, image 3 of 3
      • Lift the battery up and out of the chassis.
      Ask FixBot
    1. CHUWI GemiBook XPro Screen Replacement, Screen: step 6, image 1 of 1
      • Carefully open the device screen side down.
      Ask FixBot
    2. CHUWI GemiBook XPro Screen Replacement: step 7, image 1 of 3 CHUWI GemiBook XPro Screen Replacement: step 7, image 2 of 3 CHUWI GemiBook XPro Screen Replacement: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 4.3 mm screws on the left hinge, and the three 4.3 mm screws on the right hinge.
      • Use a Phillips #1 screwdriver to remove one 5.6 mm hinge screw on the lower-right side of the right hinge.
      Ask FixBot
    3. CHUWI GemiBook XPro Screen Replacement: step 8, image 1 of 3 CHUWI GemiBook XPro Screen Replacement: step 8, image 2 of 3 CHUWI GemiBook XPro Screen Replacement: step 8, image 3 of 3
      • Peel back the black tape near the right hinge.
      Ask FixBot
    4. CHUWI GemiBook XPro Screen Replacement: step 9, image 1 of 2 CHUWI GemiBook XPro Screen Replacement: step 9, image 2 of 2
      • Disconnect the display ribbon cable.
      Ask FixBot
    5. CHUWI GemiBook XPro Screen Replacement: step 10, image 1 of 2 CHUWI GemiBook XPro Screen Replacement: step 10, image 2 of 2
      • Lift the screen assembly off of the chassis.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
No se por que cuando cliqueo por algunos segundos la pantalla se me pone negra pero sigue ahi, que será ?
Pochy - Reply Share
Past 24 Hours: 2
Past 7 Days: 39
Past 30 Days: 108
All Time: 971
