CHUWI GemiBook XPro SSD Replacement
  1. CHUWI GemiBook XPro SSD Replacement, Battery: step 1, image 1 of 2 CHUWI GemiBook XPro SSD Replacement, Battery: step 1, image 2 of 2
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro SSD Replacement: step 2, image 1 of 2 CHUWI GemiBook XPro SSD Replacement: step 2, image 2 of 2
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro SSD Replacement: step 3, image 1 of 3 CHUWI GemiBook XPro SSD Replacement: step 3, image 2 of 3 CHUWI GemiBook XPro SSD Replacement: step 3, image 3 of 3
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro SSD Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro SSD Replacement: step 5, image 1 of 3 CHUWI GemiBook XPro SSD Replacement: step 5, image 2 of 3 CHUWI GemiBook XPro SSD Replacement: step 5, image 3 of 3
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro SSD Replacement, SSD: step 6, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw securing the SSD.
  7. CHUWI GemiBook XPro SSD Replacement: step 7, image 1 of 3 CHUWI GemiBook XPro SSD Replacement: step 7, image 2 of 3 CHUWI GemiBook XPro SSD Replacement: step 7, image 3 of 3
    • Carefully grip and pull the SSD out of its port.
    • Make sure to purchase the correct form factor of the SSD. The CHUWI GemiBook XPro uses 2280 size M.2 SSD.
JakeV
413 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 576
