Introduction
The CHUWI GemiBook XPro may have overheating issues which may cause damage to the CPU and other components which could be caused by a defective fan. This step-by-step guide can be immediately followed after the Battery Replacement Guide regarding opening up this device. The tools required for this guide are the Spudger and a Philips 1 screwdriver. Please refer to our Fan Troubleshooting page for an extended list of symptoms and alternative solutions.
Orient the device to where you can see the bottom of the case.
Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
1 Guide Comment
Where did you get the replacement fan ? I'm unable to find one with the long wire connector
