Introduction
You may find it necessary to replace the battery on the CHUWI GemiBook XPro due to its charging rate or capacity. This easy-to-follow guide will assist in the process of battery removal and replacement. For this guide you’ll need a philips #1 screwdriver, the spudger, and opening picks in order to disassemble and replace the battery in an orderly fashion.
Orient the device to where you can see the bottom of the case.
Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
For optimal performance, after completing this guide, calibrate your newly installed battery.
