CAT S62 Daughterboard Replacement
    1. CAT S62 Daughterboard Replacement, Battery: step 1, image 1 of 2 CAT S62 Daughterboard Replacement, Battery: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25% (a charged lithium-ion battery can be a safety hazard). Turn the device off before working on it.
      • Use the plastic spudger to gently pry off the rubber back panel. If needed, use the plastic iFixit opening picks to help keep the plate separated. (Heating the back of the phone using a blow dryer may help loosen adhesive.)
      • Gently pull the back panel away to avoid damaging the connecting wire for the fingerprint sensor.
      Ask FixBot
    2. CAT S62 Daughterboard Replacement: step 2, image 1 of 2 CAT S62 Daughterboard Replacement: step 2, image 2 of 2
      • Gently remove the wire connecting the back cover to the rest of the phone using your fingers or tweezers.
      • Do not pull on the wire, as it may damage the cable.
      Ask FixBot
    3. CAT S62 Daughterboard Replacement: step 3, image 1 of 3 CAT S62 Daughterboard Replacement: step 3, image 2 of 3 CAT S62 Daughterboard Replacement: step 3, image 3 of 3
      • Remove the eleven 5mm screws with a JIS #00 screwdriver.
      • Remove the six 3mm screws (three screws on each side) with a Hex 1.3 mm screwdriver.
      Ask FixBot
    4. CAT S62 Daughterboard Replacement: step 4, image 1 of 1
      • The battery cover is connected to the camera cover, so both covers must be removed to access the battery.
      • Pry off the camera cover using the iFixit opening picks.
      • Remove both plates.
      • The two plates are connected by a small wire. Handle with care and do not separate them from each other.
      Ask FixBot
    5. CAT S62 Daughterboard Replacement: step 5, image 1 of 2 CAT S62 Daughterboard Replacement: step 5, image 2 of 2
      • Disconnect the wire attached to the battery using the tweezers or your fingers.
      Ask FixBot
    6. CAT S62 Daughterboard Replacement: step 6, image 1 of 1
      • Use a blow dryer or other heating device for a few minutes to loosen the adhesive beneath the battery.
      • Be extremely careful handling heated metal, as it will be hot to the touch.
      • Pry the battery away using the plastic spudger and iFixit opening picks.
      Ask FixBot
    1. CAT S62 Daughterboard Replacement, Bottom Speaker: step 7, image 1 of 1
      • Remove the three 5mm screws using a JIS #00 screwdriver.
      Ask FixBot
    2. CAT S62 Daughterboard Replacement: step 8, image 1 of 2 CAT S62 Daughterboard Replacement: step 8, image 2 of 2
      • Gently pull the speaker upwards to remove it.
      Ask FixBot
    1. CAT S62 Daughterboard Replacement, Daughterboard: step 9, image 1 of 1
      • Remove the 2 mm screw from the daughterboard using a JIS #00 screwdriver.
      Ask FixBot
    2. CAT S62 Daughterboard Replacement: step 10, image 1 of 1
      • Using the precision tweezers, gently unclip the white wire from the daughterboard.
      Ask FixBot
    3. CAT S62 Daughterboard Replacement: step 11, image 1 of 1
      • Use precision tweezers to unclip the USB-C charging port from the daughterboard.
      Ask FixBot
    4. CAT S62 Daughterboard Replacement: step 12, image 1 of 1
      • Carefully remove the daughterboard.
      Ask FixBot
Kristen Gismondi
109,392 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 65
All Time: 226
