CAT S48c Battery Replacement
    1. CAT S48c Battery Replacement, Battery: step 1, image 1 of 2 CAT S48c Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the ten T5 Torx 4 mm-long screws on the sides of the case.
      Ask FixBot
    2. CAT S48c Battery Replacement: step 2, image 1 of 2 CAT S48c Battery Replacement: step 2, image 2 of 2
      • Open the side covers and remove the SIM card with tweezers or a pick.
      • If there is an SD card remove that as well.
      Ask FixBot
    3. CAT S48c Battery Replacement: step 3, image 1 of 3 CAT S48c Battery Replacement: step 3, image 2 of 3 CAT S48c Battery Replacement: step 3, image 3 of 3
      • Use an opening pick to pry off the rear cover.
      Ask FixBot
    4. CAT S48c Battery Replacement: step 4, image 1 of 3 CAT S48c Battery Replacement: step 4, image 2 of 3 CAT S48c Battery Replacement: step 4, image 3 of 3
      • Remove the five 3 mm-long Phillips #000 screws that secure the lower midframe.
      Ask FixBot
    5. CAT S48c Battery Replacement: step 5, image 1 of 2 CAT S48c Battery Replacement: step 5, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    6. CAT S48c Battery Replacement: step 6, image 1 of 3 CAT S48c Battery Replacement: step 6, image 2 of 3 CAT S48c Battery Replacement: step 6, image 3 of 3
      • Remove the five 3 mm-long Phillips #000 screws from the top section of the midframe.
      • Gently pry the section along with the battery off of the case.
      Ask FixBot
    7. CAT S48c Battery Replacement: step 7, image 1 of 2 CAT S48c Battery Replacement: step 7, image 2 of 2
      • Gently pry the battery from the case, making sure not to bend the battery.
      • Replace the battery with your replacement, popping it in the frame and insert the flex cable.
      • Keep in mind that if it has lumps or damages it could be dangerous to handle as it can catch on fire.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 27
All Time: 274
