Brother XR-40 Lightbulb Replacement
  1. Brother XR-40 Lightbulb Replacement, Back Panel: step 1, image 1 of 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Lightbulb Replacement: step 2, image 1 of 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Lightbulb Replacement: step 3, image 1 of 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Lightbulb Replacement: step 4, image 1 of 1
    • Remove the bottom panel.
  5. Brother XR-40 Lightbulb Replacement: step 5, image 1 of 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Lightbulb Replacement, Lightbulb: step 6, image 1 of 1
    • Using scissors, clip the two zip ties securing the lightbulb wire.
  7. Brother XR-40 Lightbulb Replacement: step 7, image 1 of 1
    • Place the machine on its side, with access to the bottom.
    • Gently pull out the white wire connecting the bulb to the machine.
  8. Brother XR-40 Lightbulb Replacement: step 8, image 1 of 1
    • Move the wire out from under the plastic hook.
  9. Brother XR-40 Lightbulb Replacement: step 9, image 1 of 1
    • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
  10. Brother XR-40 Lightbulb Replacement: step 10, image 1 of 1
    • Remove the lightbulb assembly.
Kevin Bickers
673 Reputation
4 Guides authored
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Members
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 16
All Time: 3,063
