BolaButty X-GO C27-C Charging Port Replacement
  1. BolaButty X-GO C27-C Charging Port Replacement, Charging Port: step 1, image 1 of 3 BolaButty X-GO C27-C Charging Port Replacement, Charging Port: step 1, image 2 of 3 BolaButty X-GO C27-C Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
    • Strike the speaker endcap firmly against a solid surface to pop the end caps off.
    • Removing the end caps requires a good amount of force. There is a realistic chance that you will damage your speaker or break the caps.
  2. BolaButty X-GO C27-C Charging Port Replacement: step 2, image 1 of 2 BolaButty X-GO C27-C Charging Port Replacement: step 2, image 2 of 2
    • Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
    • Remove the speaker cover.
  3. BolaButty X-GO C27-C Charging Port Replacement: step 3, image 1 of 2 BolaButty X-GO C27-C Charging Port Replacement: step 3, image 2 of 2
    • Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
    • Gently pull apart the two halves of the speaker.
    • Take care not to strain the cables.
  4. BolaButty X-GO C27-C Charging Port Replacement: step 4, image 1 of 2 BolaButty X-GO C27-C Charging Port Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
    • Separate the charging port from the battery.
  5. BolaButty X-GO C27-C Charging Port Replacement: step 5, image 1 of 2 BolaButty X-GO C27-C Charging Port Replacement: step 5, image 2 of 2
    • Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
    • While pulling up on the latch, remove the ribbon.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
jcate
497 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 259
