Blink Outdoor 4 Camera Replacement
    1. Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: step 1, image 1 of 3 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: step 1, image 2 of 3 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: step 1, image 3 of 3
      • Remove the mounting bracket from the device if necessary.
      • Flip the camera upside down.
      • The word 'Blink' should be at the top.
      • Insert the swivel multi-tool that was included in the Blink Outdoor 4 box into the small notch located inside the silver circle in the center of the device.
      • Twist to the left until you hear a click.
      Ask FixBot
    2. Blink Outdoor 4 Camera Replacement: step 2, image 1 of 2 Blink Outdoor 4 Camera Replacement: step 2, image 2 of 2
      • Use a spudger to gently pry the back casing off the device.
      • Remove the two batteries and set them aside.
      • When reattaching the back casing, turn the swivel tool to the right.
      Ask FixBot
    3. Blink Outdoor 4 Camera Replacement: step 3, image 1 of 2 Blink Outdoor 4 Camera Replacement: step 3, image 2 of 2
      • Remove all four screws near the battery compartments using a Phillips #1 screwdriver.
      • Make sure to keep track of the screws for reassembly.
      Ask FixBot
    4. Blink Outdoor 4 Camera Replacement: step 4, image 1 of 3 Blink Outdoor 4 Camera Replacement: step 4, image 2 of 3 Blink Outdoor 4 Camera Replacement: step 4, image 3 of 3
      • Turn the device on its side.
      • Use a plastic spudger to gently pry off the front cover of the device.
      Ask FixBot
    5. Blink Outdoor 4 Camera Replacement: step 5, image 1 of 3 Blink Outdoor 4 Camera Replacement: step 5, image 2 of 3 Blink Outdoor 4 Camera Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two small black screws in the upper right corner of the board.
      • Make sure to keep the screws for reassembly.
      • Gently lift the motherboard out of the device by its edges.
      • Do not pull on the board because it's attached to some cables from underneath and it could damage the device.
      Ask FixBot
    6. Blink Outdoor 4 Camera Replacement: step 6, image 1 of 3 Blink Outdoor 4 Camera Replacement: step 6, image 2 of 3 Blink Outdoor 4 Camera Replacement: step 6, image 3 of 3
      • Squeeze the edges of the white camera connector and slide it out of the socket on the motherboard.
      • If that doesn't work, use the point of a spudger to push on alternating sides of the white camera connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • Remove the camera from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Delaney Hye
749 Reputation
5 Guides authored
Texas Tech, Team 11-5, Weston Spring 2026 Member of Texas Tech, Team 11-5, Weston Spring 2026
TTU-WESTON-S26S11G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 163
All Time: 651
