Introduction
This guide will show you how to:
- Remove the battery
- Remove the front cover
- Replace the front panel
In addition to removing these parts, it is essential to be very careful in removing these parts due to the fact that this device will be reassembled.
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
