Introduction
This guide will show you how to:
- Remove the battery
- Remove the front cover
- Replace the front panel
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
