BlackBerry Passport Camera Replacement
    1. BlackBerry Passport Camera Replacement, Motherboard: step 1, image 1 of 3 BlackBerry Passport Camera Replacement, Motherboard: step 1, image 2 of 3 BlackBerry Passport Camera Replacement, Motherboard: step 1, image 3 of 3
      • Flip the phone on its front.
      Ask FixBot
    2. BlackBerry Passport Camera Replacement: step 2, image 1 of 2 BlackBerry Passport Camera Replacement: step 2, image 2 of 2
      • Remove the top SIM/microSD card cover by the notch.
      Ask FixBot
    3. BlackBerry Passport Camera Replacement: step 3, image 1 of 1
      • Remove the top two 7 mm screws using a T4 Torx screwdriver.
      • Remove the bottom three 5 mm screws using a T4 Torx screwdriver.
      Ask FixBot
    4. BlackBerry Passport Camera Replacement: step 4, image 1 of 3 BlackBerry Passport Camera Replacement: step 4, image 2 of 3 BlackBerry Passport Camera Replacement: step 4, image 3 of 3
      • Flip the phone to its back.
      Ask FixBot
    5. BlackBerry Passport Camera Replacement: step 5, image 1 of 3 BlackBerry Passport Camera Replacement: step 5, image 2 of 3 BlackBerry Passport Camera Replacement: step 5, image 3 of 3
      • Remove the cover located under the keyboard.
      Ask FixBot
    6. BlackBerry Passport Camera Replacement: step 6, image 1 of 1
      • Remove the two 6 mm screws using the T4 Torx screwdriver.
      Ask FixBot
    7. BlackBerry Passport Camera Replacement: step 7, image 1 of 3 BlackBerry Passport Camera Replacement: step 7, image 2 of 3 BlackBerry Passport Camera Replacement: step 7, image 3 of 3
      Ask FixBot
    8. BlackBerry Passport Camera Replacement: step 8, image 1 of 3 BlackBerry Passport Camera Replacement: step 8, image 2 of 3 BlackBerry Passport Camera Replacement: step 8, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    9. BlackBerry Passport Camera Replacement: step 9, image 1 of 3 BlackBerry Passport Camera Replacement: step 9, image 2 of 3 BlackBerry Passport Camera Replacement: step 9, image 3 of 3
      • Remove the black tape from the battery and the motherboard.
      Ask FixBot
    10. BlackBerry Passport Camera Replacement: step 10, image 1 of 1
      • Remove the five 4 mm screws using a T4 Torx screwdriver.
      • Remove the two 3 mm screws using a T4 Torx screwdriver.
      Ask FixBot
    11. BlackBerry Passport Camera Replacement: step 11, image 1 of 1
      • Disconnect the left four connectors.
      Ask FixBot
    12. BlackBerry Passport Camera Replacement: step 12, image 1 of 3 BlackBerry Passport Camera Replacement: step 12, image 2 of 3 BlackBerry Passport Camera Replacement: step 12, image 3 of 3
      • Remove the motherboard.
      Ask FixBot
    1. BlackBerry Passport Camera Replacement, Camera: step 13, image 1 of 3 BlackBerry Passport Camera Replacement, Camera: step 13, image 2 of 3 BlackBerry Passport Camera Replacement, Camera: step 13, image 3 of 3
      • Flip the motherboard so the back of the board faces upwards.
      Ask FixBot
    2. BlackBerry Passport Camera Replacement: step 14, image 1 of 3 BlackBerry Passport Camera Replacement: step 14, image 2 of 3 BlackBerry Passport Camera Replacement: step 14, image 3 of 3
      • Remove the connection to the motherboard and remove the camera.
      Ask FixBot
Kristen Gismondi
109,248 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 57
All Time: 336
