BlackBerry Curve 8900 Motherboard Replacement
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: step 2, image 1 of 2 BlackBerry Curve 8900 Motherboard Replacement: step 2, image 2 of 2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Using a small iFixit opening tool, remove the lower rear cover.
  4. BlackBerry Curve 8900 Motherboard Replacement: step 4, image 1 of 1
    • Remove six screws from the midframe of the device.
  5. BlackBerry Curve 8900 Motherboard Replacement: step 5, image 1 of 1
    • Remove the midframe from the phone.
  6. BlackBerry Curve 8900 Motherboard Replacement: step 6, image 1 of 2 BlackBerry Curve 8900 Motherboard Replacement: step 6, image 2 of 2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case until the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: step 7, image 1 of 2 BlackBerry Curve 8900 Motherboard Replacement: step 7, image 2 of 2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Carefully disconnect the antenna from the motherboard.
  8. BlackBerry Curve 8900 Motherboard Replacement: step 8, image 1 of 1
    • Carefully disconnect the ribbon cable on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: step 9, image 1 of 2 BlackBerry Curve 8900 Motherboard Replacement: step 9, image 2 of 2
    • Remove the screen so that it does not get damaged.
  10. BlackBerry Curve 8900 Motherboard Replacement: step 10, image 1 of 2 BlackBerry Curve 8900 Motherboard Replacement: step 10, image 2 of 2
    • Lift the up motherboard from the bottom edge to reveal to ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard and display.
Johnny Tran
473 Reputation
4 Guides authored
Cuesta, Team 1-3, Zipperian Fall 2011 Member of Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 16
All Time: 4,095
