Black and Decker BDERO100 Motor Replacement
  1. Black and Decker BDERO100 Motor Replacement, Hook and Loop System: step 1, image 1 of 1
    • Remove the sanding paper from the velcro.
  2. Black and Decker BDERO100 Motor Replacement: step 2, image 1 of 1
    • Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
  3. Black and Decker BDERO100 Motor Replacement: step 3, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 3, image 2 of 2
    • Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
    • Be careful not to lose the lock washers (black rings).
  4. Black and Decker BDERO100 Motor Replacement: step 4, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 4, image 2 of 2
    • Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
  5. Black and Decker BDERO100 Motor Replacement, Chassis: step 5, image 1 of 2 Black and Decker BDERO100 Motor Replacement, Chassis: step 5, image 2 of 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  6. Black and Decker BDERO100 Motor Replacement: step 6, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 6, image 2 of 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  7. Black and Decker BDERO100 Motor Replacement: step 7, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 7, image 2 of 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  8. Black and Decker BDERO100 Motor Replacement: step 8, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 8, image 2 of 2
    • Hold the chassis and separate it from the device.
  9. Black and Decker BDERO100 Motor Replacement, Motor: step 9, image 1 of 3 Black and Decker BDERO100 Motor Replacement, Motor: step 9, image 2 of 3 Black and Decker BDERO100 Motor Replacement, Motor: step 9, image 3 of 3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  10. Black and Decker BDERO100 Motor Replacement: step 10, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 10, image 2 of 2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  11. Black and Decker BDERO100 Motor Replacement: step 11, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 11, image 2 of 2
    • Hold the motor and gently pull to remove from chassis.
  12. Black and Decker BDERO100 Motor Replacement: step 12, image 1 of 3 Black and Decker BDERO100 Motor Replacement: step 12, image 2 of 3 Black and Decker BDERO100 Motor Replacement: step 12, image 3 of 3
    • Gently pull on all cables connected to the motor to remove.
  13. Black and Decker BDERO100 Motor Replacement: step 13, image 1 of 2 Black and Decker BDERO100 Motor Replacement: step 13, image 2 of 2
    • Once all cables are disconnected, you can proceed to replace the motor.
Irene Zubillaga
617 Reputation
5 Guides authored
USF Tampa, Team 1-5, Sullivan Spring 2016 Member of USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 15
All Time: 1,643
