Introduction
This guide describes how to replace the motor assembly from inside of the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process are the TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
Separate both sides and open the device.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
With yout hands, hold and separate the power button from the external case by pulling gently.
