Black and Decker BDEDMT Power Cord Replacement
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: step 1, image 1 of 2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: step 1, image 2 of 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: step 2, image 1 of 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: step 2, image 2 of 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: step 2, image 3 of 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: step 3, image 1 of 2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: step 3, image 2 of 2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: step 4, image 1 of 2 Black and Decker BDEDMT Power Cord Replacement: step 4, image 2 of 2
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: step 5, image 1 of 2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: step 5, image 2 of 2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: step 6, image 1 of 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: step 6, image 2 of 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: step 6, image 3 of 3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
cayla dahl
247 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2016 Member of UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Members
11 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 34
All Time: 2,069
