Introduction
Before diving into the replacement of your drill power cord, it will be helpful to know that this is a fairly easy replacement with few steps and few tools. Remember to disconnect the power cord from a wall outlet before disconnecting any wires.
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
There will be a white cord that runs from the power cord base to the circuit board located slightly above.
Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
Physically pull up on the trigger device and remove it from the armature.
Flip trigger device over onto its back.
There is a screw labeled 3 located on the bottom left of the back of the trigger device.
Use a JIS 0 to remove screw.
Gently tug on the black wire to pull the wire out of the device.
