Bionaire BAP 600 Outer Shell Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
81
All Time:
1,307
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This guide will show the user how to remove the outer casing of the Bionaire BAP 600.
Tools
    1. Bionaire BAP 600 Outer Shell Replacement, Base/Intake: step 1, image 1 of 1
      • Rotate the base counterclockwise, supporting the top with your opposite hand.
      Ask FixBot
    2. Bionaire BAP 600 Outer Shell Replacement: step 2, image 1 of 1
      • Pull the base away from the housing to expose the air filter.
      Ask FixBot
    1. Bionaire BAP 600 Outer Shell Replacement, Air Filter: step 3, image 1 of 1
      • Grab the edge of the filter housing and pull the filter away from the rest of the device.
      Ask FixBot
    2. Bionaire BAP 600 Outer Shell Replacement: step 4, image 1 of 1
      • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
      Ask FixBot
    1. Bionaire BAP 600 Outer Shell Replacement, Outer Shell: step 5, image 1 of 1
      • Remove all 6 screws from the LED housing.
      Ask FixBot
    2. Bionaire BAP 600 Outer Shell Replacement: step 6, image 1 of 1
      • After the 6 screws are removed, remove the LED housing from the bottom of the device by lifting it off.
      Ask FixBot
    3. Bionaire BAP 600 Outer Shell Replacement: step 7, image 1 of 1
      • Using two fingers lift the translucent LED cover from the inside. Repeat this step for the second tab.
      Ask FixBot
    4. Bionaire BAP 600 Outer Shell Replacement: step 8, image 1 of 1
      • After lifting 45 degrees, pull the translucent tab away from thee housing. Repeat this step for the second LED cover.
      Ask FixBot
    5. Bionaire BAP 600 Outer Shell Replacement: step 9, image 1 of 1
      • Locate the tab about 1 inch below the top vent. Insert a flat tool laterally past the tab and press in toward the center of the device. As the tab is being held down, pull the two halves of the egg apart to keep the shell open.
      Ask FixBot
    6. Bionaire BAP 600 Outer Shell Replacement: step 10, image 1 of 1
      • Locate the second tab on the back of the device approximately 2 inches above the power cord.
      • Insert the flat tool at a slight angle toward the left of the power cord. Depress the tab and pull the two halves of the shell apart.
      Ask FixBot
    7. Bionaire BAP 600 Outer Shell Replacement: step 11, image 1 of 1
      • Locate the bottom tab on the front side at the same height as the bottom tab on the back side.
      • Depress the tab using a flat tool at a slight angle and pull the halves apart.
      Ask FixBot
    8. Bionaire BAP 600 Outer Shell Replacement: step 12, image 1 of 1
      • Locate the last tab about one inch below the top on the front side.
      • Depress the tab using the flat tool at a slight angle and finish pulling the removable half of the shell off.
      Ask FixBot
    9. Bionaire BAP 600 Outer Shell Replacement: step 13, image 1 of 1
      • Locate the screw housing opposite of the control board, and remove the screw.
      Ask FixBot
    10. Bionaire BAP 600 Outer Shell Replacement: step 14, image 1 of 1
      • Locate the control board and grab it by the top and bottom firmly. Pull the board straight out being careful not to flex the circuit while removing.
      Ask FixBot
    11. Bionaire BAP 600 Outer Shell Replacement: step 15, image 1 of 1
      • Locate the screw that was being hidden by the control board and remove it to release the second half of the shell.
      Ask FixBot
    12. Bionaire BAP 600 Outer Shell Replacement: step 16, image 1 of 1
      • Remove the released half of the shell to finish removing the entire outer shell of the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
Nick Miller
182 Reputation
3 Guides authored
IUPUI, Team 4-4, Baechle Fall 2016 Member of IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 81
All Time: 1,307
