Battery Mounting Bracket Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Battery Mounting Bracket Removal, Before you begin: step 1, image 1 of 3 Battery Mounting Bracket Removal, Before you begin: step 1, image 2 of 3 Battery Mounting Bracket Removal, Before you begin: step 1, image 3 of 3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      Ask FixBot
    2. Battery Mounting Bracket Removal, Remove the back cover screws: step 2, image 1 of 2 Battery Mounting Bracket Removal, Remove the back cover screws: step 2, image 2 of 2
      Tool used on this step:
      TR6 Torx Security Screwdriver
      $5.99
      Buy
      Ask FixBot
    3. Battery Mounting Bracket Removal, Remove the back cover: step 3, image 1 of 2 Battery Mounting Bracket Removal, Remove the back cover: step 3, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Battery Mounting Bracket Removal, Remove the battery: step 4, image 1 of 3 Battery Mounting Bracket Removal, Remove the battery: step 4, image 2 of 3 Battery Mounting Bracket Removal, Remove the battery: step 4, image 3 of 3
      • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
      • Lift the right edge of the battery to remove it.
      • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
      Ask FixBot
    1. Battery Mounting Bracket Removal, Remove the mounting bracket screws: step 5, image 1 of 2 Battery Mounting Bracket Removal, Remove the mounting bracket screws: step 5, image 2 of 2
      • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
      • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
      Ask FixBot
    2. Battery Mounting Bracket Removal, Remove the mounting bracket: step 6, image 1 of 2 Battery Mounting Bracket Removal, Remove the mounting bracket: step 6, image 2 of 2
      Ask FixBot
Finish Line
Spencer Day
205,821 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 107
