Battery Disconnection
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
13
All Time:
138
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This guide shows how to disconnect the battery in your Samsung Galaxy S25 Edge smartphone.
Tools
    1. Battery Disconnection, Prepare your phone for disassembly: step 1, image 1 of 2 Battery Disconnection, Prepare your phone for disassembly: step 1, image 2 of 2
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if accidentally damaged.
      • Completely power off your phone and unplug all cables.
      Ask FixBot
    1. Battery Disconnection, Heat the bottom edge: step 2, image 1 of 1
      • Mild adhesive secures the back cover. Heating it will soften the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the back cover for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate to heat the cover.
      Ask FixBot
    2. Battery Disconnection, Apply a suction handle: step 3, image 1 of 2 Battery Disconnection, Apply a suction handle: step 3, image 2 of 2
      • Apply a suction handle near the center of the back cover's bottom edge, as close to the edge as possible.
      Ask FixBot
    3. Battery Disconnection, Insert an opening pick: step 4, image 1 of 3 Battery Disconnection, Insert an opening pick: step 4, image 2 of 3 Battery Disconnection, Insert an opening pick: step 4, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. Battery Disconnection, Adhesive information: step 5, image 1 of 3 Battery Disconnection, Adhesive information: step 5, image 2 of 3 Battery Disconnection, Adhesive information: step 5, image 3 of 3
      • The back cover is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
      • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and interconnect cable.
      Ask FixBot
    5. Battery Disconnection, Separate the adhesive: step 6, image 1 of 3 Battery Disconnection, Separate the adhesive: step 6, image 2 of 3 Battery Disconnection, Separate the adhesive: step 6, image 3 of 3
      • If you have trouble separating the adhesive, apply more heat and try again.
      • Slide your opening pick along the bottom edge to separate the adhesive securing the back cover.
      Ask FixBot
    6. Battery Disconnection: step 7, image 1 of 3 Battery Disconnection: step 7, image 2 of 3 Battery Disconnection: step 7, image 3 of 3
      • Continue sliding your pick around the entire perimeter of the back cover to separate all the remaining adhesive.
      • Remember not to insert your pick too far under the long left and right edges.
      Ask FixBot
    7. Battery Disconnection, Remove the back cover: step 8, image 1 of 2 Battery Disconnection, Remove the back cover: step 8, image 2 of 2
      • Remove the back cover.
      • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Check your rear cameras for any smudges and gently wipe them with a clean lint–free cloth if necessary.
      • Your replacement back cover adhesive will be applied to either the frame or the back cover. Use cutouts and contours to see where it lines up best. If it matches the back cover, follow this guide. If it matches the frame, use this guide.
      Ask FixBot
    1. Battery Disconnection, Disconnect the wireless charging assembly: step 9, image 1 of 2 Battery Disconnection, Disconnect the wireless charging assembly: step 9, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the wireless charging assembly press connector from its top edge.
      • Getting the spudger under the connector can be tricky. If you're having trouble, try using the tip of an opening pick instead.
      Ask FixBot
    2. Battery Disconnection, Remove the wireless charging and loudspeaker assembly screws: step 10, image 1 of 3 Battery Disconnection, Remove the wireless charging and loudspeaker assembly screws: step 10, image 2 of 3 Battery Disconnection, Remove the wireless charging and loudspeaker assembly screws: step 10, image 3 of 3
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a Phillips screwdriver to remove the eleven 2.8 mm‑long screws securing the wireless charging and loudspeaker assembly.
      Ask FixBot
    3. Battery Disconnection, Pry up the loudspeaker: step 11, image 1 of 3 Battery Disconnection, Pry up the loudspeaker: step 11, image 2 of 3 Battery Disconnection, Pry up the loudspeaker: step 11, image 3 of 3
      • The wireless charging coil is connected to the loudspeaker with delicate tape. It's easiest to remove the coil and loudspeaker together as one assembly to avoid damage.
      • Use angled tweezers to pry up and unclip the loudspeaker by the notch on its left edge.
      • During reassembly, press down firmly around the perimeter of the loudspeaker to engage its clips.
      Ask FixBot
    4. Battery Disconnection, Remove the wireless charging assembly: step 12, image 1 of 2 Battery Disconnection, Remove the wireless charging assembly: step 12, image 2 of 2
      • Use two hands to lift and remove the wireless charging and loudspeaker assembly.
      Ask FixBot
    1. Battery Disconnection, Disconnect the battery: step 13, image 1 of 2 Battery Disconnection, Disconnect the battery: step 13, image 2 of 2
      • Every press connector has a corresponding gold arrow on the board that shows the proper location to pry—nifty! Prying at the wrong location risks damaging the fragile surface‑mounted components on the board.
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
Finish Line
Spencer Day
208,025 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 138
