Introduction
Prereq for disconnecting the battery. Also includes a generic disclaimer about the coating.
Lay your eReader down so the back cover is facing up.
Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
Push the pick downwards at a slight angle until it slides under the back cover.
Slide the pick toward the bottom right corner to release the clips along the bottom edge.
Slide the pick toward the top left corner to release the clips along the left edge.
Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
Remove the back cover.
The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
The ZIF connector locking tabs are coated in a gel that can jam the hinge and keep the locking tab from completely unlocking. Make sure the tabs are completely upright before disconnecting any cables.
Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
Heat an iOpener and lay it on the battery connector for 90 seconds to soften the coating.
Tool used on this step:Tweezers$4.99
Use the tip of a spudger to scrape up the coating along the white battery connector head—enough so you can grab clumps of it with pointed tweezers.
Insert the point of a spudger under the edge of the battery connector head opposite of the cable.
Lift up the connector with the spudger to separate the rest of the coating and disconnect the battery.
Inspect the connector head and its socket for any remaining coating that could prevent a good connection.
Peel off the coating, heating the area when the coating becomes too brittle.
