Shop the Holiday Gift Guide
Battery Disconnection
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
20
All Time:
186
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the Xiaomi Redmi Note 9T.
Tools
    1. Battery Disconnection, Eject the SIM card tray: step 1, image 1 of 3 Battery Disconnection, Eject the SIM card tray: step 1, image 2 of 3 Battery Disconnection, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the upper left edge edge of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. Battery Disconnection, Remove the SIM card tray: step 2, image 1 of 2 Battery Disconnection, Remove the SIM card tray: step 2, image 2 of 2
      • Remove the SIM card tray from the phone.
      • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
      Ask FixBot
    1. Battery Disconnection, Insert an opening pick: step 3, image 1 of 3 Battery Disconnection, Insert an opening pick: step 3, image 2 of 3 Battery Disconnection, Insert an opening pick: step 3, image 3 of 3
      • The back cover of the Redmi Note 9T is held in place by plastic clips and mild adhesive around the camera cut-out. It might require some force to release the plastic clips.
      • Insert an opening pick in a steep angle between the display assembly and the back cover where the charging port is located. This might require some force.
      • Make sure to insert the opening pick between the back cover and the display frame to avoid separating the screen from the frame.
      Ask FixBot
    2. Battery Disconnection, Release the bottom edge plastic clips: step 4, image 1 of 2 Battery Disconnection, Release the bottom edge plastic clips: step 4, image 2 of 2
      • Slide the opening pick to the bottom right corner to release the plastic clips holding the back cover in place.
      • Leave the opening pick in the bottom right corner to prevent the clips from snapping back into place.
      Ask FixBot
    3. Battery Disconnection: step 5, image 1 of 2 Battery Disconnection: step 5, image 2 of 2
      • Insert a second opening pick in a steep angle at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to release the plastic clips.
      • Leave the opening pick in the bottom left corner to prevent the clips from snapping back into place.
      Ask FixBot
    4. Battery Disconnection, Release the left edge plastic clips: step 6, image 1 of 3 Battery Disconnection, Release the left edge plastic clips: step 6, image 2 of 3 Battery Disconnection, Release the left edge plastic clips: step 6, image 3 of 3
      • Slide the bottom left opening pick along the left edge of your phone to release the plastic clips.
      • Leave the opening pick in the top left corner to prevent the clips from snapping back into place.
      Ask FixBot
    5. Battery Disconnection, Release the right edge plastic clips: step 7, image 1 of 3 Battery Disconnection, Release the right edge plastic clips: step 7, image 2 of 3 Battery Disconnection, Release the right edge plastic clips: step 7, image 3 of 3
      • Slide the bottom right opening pick along the right edge of your phone to release the plastic clips.
      • Leave the opening pick in the top right corner to prevent the clips from snapping back into place.
      Ask FixBot
    6. Battery Disconnection, Release the top edge plastic clips: step 8, image 1 of 2 Battery Disconnection, Release the top edge plastic clips: step 8, image 2 of 2
      • Slide the left opening pick around the top left corner to release the top edge plastic clips.
      Ask FixBot
    7. Battery Disconnection: step 9, image 1 of 2 Battery Disconnection: step 9, image 2 of 2
      • Slide the right opening pick around the top right corner to release the remaining plastic clips.
      • Don't try to separate the phone assembly from the back cover all the way yet – the power and volume button cable is still connected to the motherboard.
      Ask FixBot
    8. Battery Disconnection, Open the phone assembly: step 10, image 1 of 3 Battery Disconnection, Open the phone assembly: step 10, image 2 of 3 Battery Disconnection, Open the phone assembly: step 10, image 3 of 3
      • Carefully fold the back cover to the left side of the phone assembly like you would open the cover of a book.
      • Take care not to strain or tear the power or volume button flex cable during this procedure.
      • During reassembly align the back cover with the phone assembly and snap it back in its original position.
      Ask FixBot
    9. Battery Disconnection, Unfasten the motherboard cover screws: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the ten 3.9 mm-long screws securing the motherboard cover.
      Ask FixBot
    10. Battery Disconnection, Pry up the motherboard cover: step 12, image 1 of 3 Battery Disconnection, Pry up the motherboard cover: step 12, image 2 of 3 Battery Disconnection, Pry up the motherboard cover: step 12, image 3 of 3
      • Insert an opening pick underneath the bottom right edge of the motherboard cover.
      • Slide the opening pick along the right edge of the motherboard cover to release its plastic clips.
      • Twist the opening pick sideways to pry up the motherboard cover.
      Ask FixBot
    11. Battery Disconnection, Remove the motherboard cover: step 13, image 1 of 2 Battery Disconnection, Remove the motherboard cover: step 13, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    12. Battery Disconnection, Disconnect the home and volume button cable: step 14, image 1 of 2 Battery Disconnection, Disconnect the home and volume button cable: step 14, image 2 of 2
      • Use a spudger to disconnect the home and volume button cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    13. Battery Disconnection, Remove the back cover: step 15, image 1 of 1
      • Separate the back cover from the phone assembly.
      Ask FixBot
    1. Battery Disconnection, Disconnect the battery cable: step 16, image 1 of 2 Battery Disconnection, Disconnect the battery cable: step 16, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xiaomi Redmi Note 9T answers community for help.
Dominik Schnabelrauch
267,900 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 186
