Shop the Holiday Gift Guide
Battery Disconnection
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
14
All Time:
248
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Parts
Tools
    1. Battery Disconnection, Heat the rear glass: step 1, image 1 of 1
      • Be sure to power off your phone before you begin.
      • Apply a heated iOpener to the rear glass for two minutes to loosen the adhesive beneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Battery Disconnection, Insert an opening pick: step 2, image 1 of 3 Battery Disconnection, Insert an opening pick: step 2, image 2 of 3 Battery Disconnection, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction handle to the right edge of the rear glass.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull on the suction handle to create a gap between the rear glass and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Battery Disconnection, Slice the adhesive: step 3, image 1 of 3 Battery Disconnection, Slice the adhesive: step 3, image 2 of 3 Battery Disconnection, Slice the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the edge to the bottom right corner.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      • Once you have inserted an opening pick, feel free to remove the suction handle or continue to use it for a better grip during this process.
      Ask FixBot
    4. Battery Disconnection: step 4, image 1 of 3 Battery Disconnection: step 4, image 2 of 3 Battery Disconnection: step 4, image 3 of 3
      • Insert a second opening pick in the gap you just created.
      • Slide the opening pick along the edge to the top right corner.
      • If you have trouble with slicing, you can use the iOpener again to soften the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Battery Disconnection: step 5, image 1 of 3 Battery Disconnection: step 5, image 2 of 3 Battery Disconnection: step 5, image 3 of 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
      • Insert a third opening pick under the top right corner of the rear glass.
      • Slide the opening pick along the edge of the phone to the top left corner to cut the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Battery Disconnection: step 6, image 1 of 3 Battery Disconnection: step 6, image 2 of 3 Battery Disconnection: step 6, image 3 of 3
      • Insert a fourth opening pick under the top left corner.
      • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Battery Disconnection: step 7, image 1 of 2 Battery Disconnection: step 7, image 2 of 2
      • Insert a fifth opening pick under the bottom left corner.
      • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
      Ask FixBot
    8. Battery Disconnection, Remove the rear glass: step 8, image 1 of 1
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Battery Disconnection, Unscrew the motherboard cover: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the eleven 3.6 mm-long screws securing motherboard cover.
      • One of the screws is hidden beneath a white water damage sticker.
      Ask FixBot
    2. Battery Disconnection, Remove motherboard cover: step 10, image 1 of 3 Battery Disconnection, Remove motherboard cover: step 10, image 2 of 3 Battery Disconnection, Remove motherboard cover: step 10, image 3 of 3
      • Insert the tip of an opening pick under the right bottom of the motherboard cover.
      • Slide the opening pick along the motherboard cover to release the plastic clips that hold it in its place.
      • Remove the motherboard cover.
      Ask FixBot
    3. Battery Disconnection, Disconnect the battery: step 11, image 1 of 2 Battery Disconnection, Disconnect the battery: step 11, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
Manuel Haeussermann
27,576 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 248
