Up to 20% off select tools
Battery Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
36
All Time:
187
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Battery Disconnect
Tools
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
    1. Battery Disconnect, Heat the left edge: step 1, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's left edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the back cover and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Battery Disconnect, Separate the left adhesive: step 2, image 1 of 3 Battery Disconnect, Separate the left adhesive: step 2, image 2 of 3 Battery Disconnect, Separate the left adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
      • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Battery Disconnect, Slice the left adhesive: step 3, image 1 of 2 Battery Disconnect, Slice the left adhesive: step 3, image 2 of 2
      • Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
      • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Battery Disconnect, Heat the top edge: step 4, image 1 of 1
      • Apply a heated iOpener to the back cover's top edge for two minutes.
      Ask FixBot
    5. Battery Disconnect: step 5, image 1 of 2 Battery Disconnect: step 5, image 2 of 2
      • Rotate the pick around the top left corner to slice the adhesive.
      Ask FixBot
    6. Battery Disconnect: step 6, image 1 of 2 Battery Disconnect: step 6, image 2 of 2
      • Slide the pick along the top edge to slice the adhesive.
      • Leave the opening pick inserted in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Battery Disconnect: step 7, image 1 of 1
      • Apply a heated iOpener to the back cover's right edge for two minutes.
      Ask FixBot
    8. Battery Disconnect: step 8, image 1 of 2 Battery Disconnect: step 8, image 2 of 2
      • Rotate the pick around the top right corner to slice the adhesive.
      Ask FixBot
    9. Battery Disconnect: step 9, image 1 of 2 Battery Disconnect: step 9, image 2 of 2
      • Slide the pick along the right edge to slice the adhesive.
      • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    10. Battery Disconnect: step 10, image 1 of 1
      • Apply a heated iOpener to the back cover's bottom edge for two minutes.
      Ask FixBot
    11. Battery Disconnect: step 11, image 1 of 2 Battery Disconnect: step 11, image 2 of 2
      • Rotate the pick around the bottom right corner to slice the adhesive.
      Ask FixBot
    12. Battery Disconnect: step 12, image 1 of 2 Battery Disconnect: step 12, image 2 of 2
      • Slide the pick along the bottom edge to slice the adhesive.
      Ask FixBot
    13. Battery Disconnect, Heat the camera adhesive: step 13, image 1 of 2 Battery Disconnect, Heat the camera adhesive: step 13, image 2 of 2
      • There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
      • Apply a heated iOpener to the right of the cameras for two minutes.
      Ask FixBot
    14. Battery Disconnect, Slice the adhesive around the camera: step 14, image 1 of 2 Battery Disconnect, Slice the adhesive around the camera: step 14, image 2 of 2
      • Insert an opening pick between the back cover and motherboard cover on the top right edge.
      • Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
      • The back cover should detach from the phone at this point.
      Ask FixBot
    15. Battery Disconnect, Remove the back cover: step 15, image 1 of 2 Battery Disconnect, Remove the back cover: step 15, image 2 of 2
      • Lift the back cover from the phone and remove it.
      • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
      • During reassembly:
      • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
      • Follow this guide to replace the back cover adhesive.
      Ask FixBot
    1. Battery Disconnect, Unfasten the motherboard cover: step 16, image 1 of 2 Battery Disconnect, Unfasten the motherboard cover: step 16, image 2 of 2
      • Use a Phillips screwdriver to remove the 13 4 mm screws securing the motherboard cover.
      Ask FixBot
    2. Battery Disconnect, Release the motherboard cover clips: step 17, image 1 of 2 Battery Disconnect, Release the motherboard cover clips: step 17, image 2 of 2
      • Insert a spudger between the motherboard cover and midframe on the top right edge of the phone.
      • Pry up with the spudger to release the clips securing the motherboard cover.
      • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
      Ask FixBot
    3. Battery Disconnect, Remove the motherboard cover: step 18, image 1 of 3 Battery Disconnect, Remove the motherboard cover: step 18, image 2 of 3 Battery Disconnect, Remove the motherboard cover: step 18, image 3 of 3
      • Gently pull the motherboard cover up and away from the phone and remove it.
      • Don't pull quickly or forcefully, as the heat spreader very loosely secures the motherboard cover to the battery.
      Ask FixBot
    1. Battery Disconnect, Disconnect the battery: step 19, image 1 of 2 Battery Disconnect, Disconnect the battery: step 19, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
Author
with
Spencer Day
210,586 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 187
