Up to 20% off select tools
Battery Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
22
All Time:
392
Comments: 7
7 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Battery Disconnect
Tools
Introduction
Go to step 1 ↓
Prereq for disconnecting the battery of your Samsung Galaxy A10.
    1. Battery Disconnect, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 1 of 2 Battery Disconnect, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 2 of 2
      • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. Battery Disconnect: step 2, image 1 of 2 Battery Disconnect: step 2, image 2 of 2
      • Remove the SIM card tray.
      • When reinserting the cards, make sure to properly orient them in the tray.
      Ask FixBot
    1. Battery Disconnect, Back Cover: step 3, image 1 of 2 Battery Disconnect, Back Cover: step 3, image 2 of 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
      Ask FixBot
    2. Battery Disconnect: step 4, image 1 of 3 Battery Disconnect: step 4, image 2 of 3 Battery Disconnect: step 4, image 3 of 3
      • Slide the opening pick to the bottom left corner to release the clips.
      Ask FixBot
    3. Battery Disconnect: step 5, image 1 of 3 Battery Disconnect: step 5, image 2 of 3 Battery Disconnect: step 5, image 3 of 3
      • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
      Ask FixBot
    4. Battery Disconnect: step 6, image 1 of 3 Battery Disconnect: step 6, image 2 of 3 Battery Disconnect: step 6, image 3 of 3
      • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
      Ask FixBot
    5. Battery Disconnect: step 7, image 1 of 3 Battery Disconnect: step 7, image 2 of 3 Battery Disconnect: step 7, image 3 of 3
      • Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
      Ask FixBot
    6. Battery Disconnect: step 8, image 1 of 2 Battery Disconnect: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Battery Disconnect, Samsung Galaxy A10 Motherboard Cover Replacement: step 9, image 1 of 1
      • Remove the three Phillips #00 screws (3 mm length).
      Ask FixBot
    2. Battery Disconnect: step 10, image 1 of 3 Battery Disconnect: step 10, image 2 of 3 Battery Disconnect: step 10, image 3 of 3
      • Use the flat end of a spudger to pry up the motherboard cover to release the plastic clips which hold the cover in its place.
      • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, twist the spudger to make the process easier.
      • Remove the motherboard cover.
      • The remaining plastic clips should release during this process or can be unhinged easily by hand.
      Ask FixBot
    1. Battery Disconnect, Battery Disconnect: step 11, image 1 of 2 Battery Disconnect, Battery Disconnect: step 11, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
Adriana Zwink
69,916 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 392
