Backbone One Left Bumper Replacement
  1. Backbone One Left Bumper Replacement, Unfasten the screws: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Bumper Replacement, Rotate the upper cover: step 2, image 1 of 3 Backbone One Left Bumper Replacement, Rotate the upper cover: step 2, image 2 of 3 Backbone One Left Bumper Replacement, Rotate the upper cover: step 2, image 3 of 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Bumper Replacement, Remove the protective tape: step 3, image 1 of 3 Backbone One Left Bumper Replacement, Remove the protective tape: step 3, image 2 of 3 Backbone One Left Bumper Replacement, Remove the protective tape: step 3, image 3 of 3
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Bumper Replacement, Open the ZIF connector: step 4, image 1 of 2 Backbone One Left Bumper Replacement, Open the ZIF connector: step 4, image 2 of 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Bumper Replacement, Disconnect the interconnect cable: step 5, image 1 of 2 Backbone One Left Bumper Replacement, Disconnect the interconnect cable: step 5, image 2 of 2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Bumper Replacement: step 6, image 1 of 2 Backbone One Left Bumper Replacement: step 6, image 2 of 2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Bumper Replacement, Remove the screw: step 7, image 1 of 2 Backbone One Left Bumper Replacement, Remove the screw: step 7, image 2 of 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Bumper Replacement, Remove the trigger: step 8, image 1 of 2 Backbone One Left Bumper Replacement, Remove the trigger: step 8, image 2 of 2
    • Remove the left trigger.
  9. Backbone One Left Bumper Replacement, Remove the bumper: step 9, image 1 of 2 Backbone One Left Bumper Replacement, Remove the bumper: step 9, image 2 of 2
    • Use your fingers to remove the left bumper.
Adriana Zwink
48,556 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,218 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 26
All Time: 587
