Azpen A720 Speaker Replacement
  1. Azpen A720 Speaker Replacement, Back Cover: step 1, image 1 of 2 Azpen A720 Speaker Replacement, Back Cover: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: step 2, image 1 of 3 Azpen A720 Speaker Replacement: step 2, image 2 of 3 Azpen A720 Speaker Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: step 3, image 1 of 1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: step 4, image 1 of 1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: step 5, image 1 of 1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: step 6, image 1 of 1
    • The speaker is a magnet and attached to the metal backing. Remove the speaker.
    • Replace the speaker with a new one.
Anna
353 Reputation
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 254
