Introduction
The speaker is responsible for all non-headphone sounds from your tablet. If these sounds are not audible when they should be you may need to replace the speaker. Speaker replacement is a relatively easy task and this guide will help you through it.
Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
Use a soldering iron to melt the connections between the black and red speaker wires and the motherboard.
Remove the speaker, it is a magnet and is loosely attached to the metal backing.
Replace the speaker with a new one.
