Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement
  1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: step 1, image 1 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: step 1, image 2 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: step 1, image 3 of 3
    • Remove the inner steel plate that spins on the turntable.
    • Carefully lift up the plate.
    • Place it near your device out of the way.
  2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 2, image 1 of 1
    • Remove the power cord in the back of the device.
  3. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 3, image 1 of 1
    • Ensure that the Tone Arm clamp is in place.
  4. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 4, image 1 of 2 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 4, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the eight 2 mm screws holding the back casing into place.
    • Carefully remove the back casing from the device to expose the interior.
  5. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: step 5, image 1 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: step 5, image 2 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: step 5, image 3 of 3
    • The Anti-Skate Knob is in the top left corner of the record player; this is what holds together the Tonearm.
    • To remove this, you must desolder the five small connections and the large one next to it.
  6. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 6, image 1 of 2 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 6, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two screws.
    • Using Snap Ring Pliers, pull up at the Snap Ring to remove it.
  7. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 7, image 1 of 2 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 7, image 2 of 2
    • Remove the 2.5 mm screws using a Phillips #2 that connects the tonearm to the record player frame.
  8. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 8, image 1 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 8, image 2 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 8, image 3 of 3
    • Unscrew the cable with the Phillips #2 screwdriver.
  9. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 9, image 1 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 9, image 2 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 9, image 3 of 3
    • Use a Philips #2 screwdriver to remove the two 2.5 mm screws, and remove the Snap Ring by pulling up at it with Snap Ring Pliers which are being highlighted.
    • DO NOT unscrew the yellow X in the picture.
    • Remove the small 0.1 mm black screw with the Phillips #000 screwdriver.
  10. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 10, image 1 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 10, image 2 of 3 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 10, image 3 of 3
    • Pull off the cover to reveal the spring.
    • Using Tweezers, pull the spring out by pulling it off of the hooks on each end.
  11. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: step 11, image 1 of 1
    • Now replace the old spring with your new one!
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ryan Barcelos
345 Reputation
1 Guide authored
Cuesta, Team 20-3, Krynen Fall 2024 Member of Cuesta, Team 20-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G3
5 Members
6 Guides authored
1 Guide Comment
Hi
Where i can find to by antiscate spring?
Thanks
Flegma - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 78
All Time: 702
