Asus Zenbook UX303L Hard Drive Replacement
  1. Asus Zenbook UX303L Hard Drive Replacement, SSD: step 1, image 1 of 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Hard Drive Replacement: step 2, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 2, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 2, image 3 of 3
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Remove two additional screws, if present, from beneath the rubber pads. (Pry up each rubber pad to access its screw.)
    • Carefully remove the bottom cover. The cover doesn't just lift up, you have to lift it to a approx. 45° angle, then pull towards the exterior (there are two small plastic claws that maintain the cover attached)
  3. Asus Zenbook UX303L Hard Drive Replacement: step 3, image 1 of 1
    • Remove the five screws attaching the battery pack by using a PH-1 screwdriver.
  4. Asus Zenbook UX303L Hard Drive Replacement: step 4, image 1 of 2 Asus Zenbook UX303L Hard Drive Replacement: step 4, image 2 of 2
    • Unhook the black, red, and white switch using the tweezers.
  5. Asus Zenbook UX303L Hard Drive Replacement: step 5, image 1 of 2 Asus Zenbook UX303L Hard Drive Replacement: step 5, image 2 of 2
    • Detach the positive and negative black, white, yellow, and red switch with the use of tweezers.
  6. Asus Zenbook UX303L Hard Drive Replacement: step 6, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 6, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 6, image 3 of 3
    • Unhook the black and white coiled wire using the tweezers.
  7. Asus Zenbook UX303L Hard Drive Replacement: step 7, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 7, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 7, image 3 of 3
    • Remove the 3 screws surrounding the hard drive using the PH-1 screwdriver.
    • Gently lift and detach the hard drive, and pull it out.
    • If your model has never been opened, you might have this "cushion sticker" that makes it difficult to unplug the hard drive. You can just peel it and put it back later.
Cindy Lopez
642 Reputation
1 Guide authored
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 88
All Time: 35,651
