Introduction
ASUS X54C, X54H, X54L, X54HR - how to replace or upgrade HDD, RAM memory, Wi-Fi module.
Video Overview
The HDD caddy iz secured by three Phillips screws. Remove them.
Use the black tape near to the SATA connector to slide and remove the HDD.
To remove the hard disk from the HDD caddy, unscrew the 2x Phillips screw.
There is one expansion slot for a memory module:
SO DIMM 204-pin, DDR3 SDRAM, 1333 MHz
Under the HDD cover is also the Wi-Fi card.
