Asus Q200E Motherboard Replacement
  1. Asus Q200E Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus Q200E Motherboard Replacement: step 2, image 1 of 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus Q200E Motherboard Replacement: step 3, image 1 of 2 Asus Q200E Motherboard Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus Q200E Motherboard Replacement, Battery: step 4, image 1 of 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus Q200E Motherboard Replacement: step 5, image 1 of 3 Asus Q200E Motherboard Replacement: step 5, image 2 of 3 Asus Q200E Motherboard Replacement: step 5, image 3 of 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus Q200E Motherboard Replacement: step 6, image 1 of 2 Asus Q200E Motherboard Replacement: step 6, image 2 of 2
    • Now just lift the battery out of place.
  7. Asus Q200E Motherboard Replacement, Cooling Fan: step 7, image 1 of 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  8. Asus Q200E Motherboard Replacement: step 8, image 1 of 1
    • Unplug the power bus for the fan.
  9. Asus Q200E Motherboard Replacement: step 9, image 1 of 1
    • Lift up and remove the cooling fan from the slot.
  10. Asus Q200E Motherboard Replacement, Wireless Card: step 10, image 1 of 2 Asus Q200E Motherboard Replacement, Wireless Card: step 10, image 2 of 2
    • Locate wireless card next to battery.
  11. Asus Q200E Motherboard Replacement: step 11, image 1 of 1
    • Remove the one 4.9mm screw that holds the wireless card in place with a Phillips #00 screwdriver.
  12. Asus Q200E Motherboard Replacement: step 12, image 1 of 1
    • Unplug the black coaxial cable from the wireless card.
  13. Asus Q200E Motherboard Replacement: step 13, image 1 of 1
    • Pull the wireless card from connector slot.
  14. Asus Q200E Motherboard Replacement, Motherboard: step 14, image 1 of 1
    • Locate the motherboard under the cooling fan.
  15. Asus Q200E Motherboard Replacement: step 15, image 1 of 1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  16. Asus Q200E Motherboard Replacement: step 16, image 1 of 1
    • Remove the PCB board from the motherboard.
  17. Asus Q200E Motherboard Replacement: step 17, image 1 of 1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  18. Asus Q200E Motherboard Replacement: step 18, image 1 of 2 Asus Q200E Motherboard Replacement: step 18, image 2 of 2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  19. Asus Q200E Motherboard Replacement: step 19, image 1 of 1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  20. Asus Q200E Motherboard Replacement: step 20, image 1 of 1
    • Carefully lift the motherboard up out of the slot.
  21. Asus Q200E Motherboard Replacement: step 21, image 1 of 2 Asus Q200E Motherboard Replacement: step 21, image 2 of 2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
Mitchell Jackson
742 Reputation
7 Guides authored
IUPUI, Team S4-G4, Wilson Summer 2017 Member of IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 2,191
