Introduction
Use this guide to open the lower case of the Asus V6800V.
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Unscrew the screws at the bottom of the chassis to remove the top panel.
The case needs to be separated. Use your fingers or a pry tool to gently start at the front and work around the entire case.
Remove the internal cables by starting with those in the front and working towards the back.
Use your fingers to gently remove the cables from their sockets.
Once you can separate the screen and top case from the bottom case, lay them flat so you can work on the computer more easily.
