Asus V6800V Lower Case Disassembly
  1. Asus V6800V Lower Case Disassembly, Battery: step 1, image 1 of 2 Asus V6800V Lower Case Disassembly, Battery: step 1, image 2 of 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Lower Case Disassembly, Keyboard: step 2, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Lower Case Disassembly: step 3, image 1 of 3 Asus V6800V Lower Case Disassembly: step 3, image 2 of 3 Asus V6800V Lower Case Disassembly: step 3, image 3 of 3
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Lower Case Disassembly: step 4, image 1 of 2 Asus V6800V Lower Case Disassembly: step 4, image 2 of 2
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
  5. Asus V6800V Lower Case Disassembly, Asus V6800V Lower Case Disassembly: step 5, image 1 of 1
    • Unscrew the screws at the bottom of the chassis to remove the top panel.
    • This will allow for the removal of the display from the rest of the computer.
  6. Asus V6800V Lower Case Disassembly: step 6, image 1 of 1
    • Under the keyboard, remove the six screws that are highlighted.
  7. Asus V6800V Lower Case Disassembly: step 7, image 1 of 2 Asus V6800V Lower Case Disassembly: step 7, image 2 of 2
    • The case needs to be separated. Use your fingers or a pry tool to gently start at the front and work around the entire case.
    • There are several cables connecting both sides of the case internally, so be gentle. The cables will be removed in the next step.
  8. Asus V6800V Lower Case Disassembly: step 8, image 1 of 3 Asus V6800V Lower Case Disassembly: step 8, image 2 of 3 Asus V6800V Lower Case Disassembly: step 8, image 3 of 3
    • Remove the internal cables by starting with those in the front and working towards the back.
    • Use your fingers to gently remove the cables from their sockets.
    • The cables connecting the display to the main chassis are difficult to pull out using your fingers. A tool of some sort (tweezers in this case) may need to be used.
    • There is one cable that connects the display to the chassis. Don't pull on it. It has no impact on the display. It is highlighted in step 9.
  9. Asus V6800V Lower Case Disassembly: step 9, image 1 of 1
    • Once you can separate the screen and top case from the bottom case, lay them flat so you can work on the computer more easily.
Brian Tubb
272 Reputation
2 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 7,731
