Asus Transformer T100 Front Panel Digitizer Replacement
  1. Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 3 of 3
    • In order to get the back cover off, use a tool you are familiar with to pry it open carefully.
  2. Asus Transformer T100 Front Panel Digitizer Replacement, Use the pick: step 2, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Use the pick: step 2, image 2 of 2
    • Insert a pick, and slowly go around the edge of the tablet to loosen the back shield
  3. Asus Transformer T100 Front Panel Digitizer Replacement, Unscrew The Screws: step 3, image 1 of 1
    • Use a Phillips #1 screw driver to loosen all the screws.
    • Make a system to organize the screws, since they have different sizes.
  4. Asus Transformer T100 Front Panel Digitizer Replacement, Battery connection: step 4, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Battery connection: step 4, image 2 of 2
    • Loosen the tape of the battery connection.
    • Be careful you don't break the wires. They can seem stuck and hard loosen up.
    • Separate the cable from the connecter.
  5. Asus Transformer T100 Front Panel Digitizer Replacement, Copper tape: step 5, image 1 of 1
    • Next step is to peel off the copper tape. Left to Right
  6. Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 3 of 3
    • Under the tape is there a connection we have to take off, plus another screw.
  7. Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 3 of 3
    • Next we have to take out the speaker because it has a connection on the motherboard.
    • In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using.
  8. Asus Transformer T100 Front Panel Digitizer Replacement, Disconnect the speaker: step 8, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Disconnect the speaker: step 8, image 2 of 2
    • Here we have to disconnect the speaker connection.
  9. Asus Transformer T100 Front Panel Digitizer Replacement, Digitizer disconnection: step 9, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Digitizer disconnection: step 9, image 2 of 2
    • Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out.
  10. Asus Transformer T100 Front Panel Digitizer Replacement, Taking out the motherboard: step 10, image 1 of 1
    • We are now ready to take out the motherboard. This is done by following all the steps to this point.
    • Carefully lift the board in both ends or in 2 of the 4 corners and slowly lift it off to the side.
  11. Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 3 of 3
    • Next step is to take out the LCD. Depending on the model # of your device screws can be placed different corners.
    • Take out the screws and lift out the LCD screen
  12. Asus Transformer T100 Front Panel Digitizer Replacement, Last step: step 12, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Last step: step 12, image 2 of 2
    • The last step is to separate the plastic frame from the old Digitizer glass.
    • I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
    • You are now ready to put your new digitizer on the plastic frame and assemble the T-100.
    • BE VERY careful when applying heat to the plastic, it can easily bend so make sure you keep your heatgun/hairdryer on low heat.
Nick Johansen
1,991 Reputation
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 83
All Time: 34,030
