Asus Transformer T100 Front Panel Digitizer Replacement
    1. Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Asus T-100 Front panel Repair: step 1, image 3 of 3
      • In order to get the back cover off, use a tool you are familiar with to pry it open carefully.
      Ask FixBot
    2. Asus Transformer T100 Front Panel Digitizer Replacement, Use the pick: step 2, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Use the pick: step 2, image 2 of 2
      • Insert a pick, and slowly go around the edge of the tablet to loosen the back shield
      Ask FixBot
    3. Asus Transformer T100 Front Panel Digitizer Replacement, Unscrew The Screws: step 3, image 1 of 1
      • Use a Phillips #1 screw driver to loosen all the screws.
      • Make a system to organize the screws, since they have different sizes.
      Ask FixBot
    4. Asus Transformer T100 Front Panel Digitizer Replacement, Battery connection: step 4, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Battery connection: step 4, image 2 of 2
      • Loosen the tape of the battery connection.
      • Be careful you don't break the wires. They can seem stuck and hard loosen up.
      • Separate the cable from the connecter.
      Ask FixBot
    5. Asus Transformer T100 Front Panel Digitizer Replacement, Copper tape: step 5, image 1 of 1
      • Next step is to peel off the copper tape. Left to Right
      Ask FixBot
    6. Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Beneath the copper tape: step 6, image 3 of 3
      • Under the tape is there a connection we have to take off, plus another screw.
      • As in step 9 later there is a white strip under the black sticky sponge that lifts to allow the ribbon tape to come out easily.
      Ask FixBot
    7. Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the speaker.: step 7, image 3 of 3
      • Next we have to take out the speaker because it has a connection on the motherboard.
      • In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using.
      Ask FixBot
    8. Asus Transformer T100 Front Panel Digitizer Replacement, Disconnect the speaker: step 8, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Disconnect the speaker: step 8, image 2 of 2
      • Here we have to disconnect the speaker connection.
      Ask FixBot
    9. Asus Transformer T100 Front Panel Digitizer Replacement, Digitizer disconnection: step 9, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Digitizer disconnection: step 9, image 2 of 2
      • Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out.
      Ask FixBot
    10. Asus Transformer T100 Front Panel Digitizer Replacement, Taking out the motherboard: step 10, image 1 of 1
      • We are now ready to take out the motherboard. This is done by following all the steps to this point.
      • Carefully lift the board in both ends or in 2 of the 4 corners and slowly lift it off to the side.
      Ask FixBot
    11. Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 1 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 2 of 3 Asus Transformer T100 Front Panel Digitizer Replacement, Taken out the LCD: step 11, image 3 of 3
      • Next step is to take out the LCD. Depending on the model # of your device screws can be placed different corners.
      • Take out the screws and lift out the LCD screen
      Ask FixBot
    12. Asus Transformer T100 Front Panel Digitizer Replacement, Last step: step 12, image 1 of 2 Asus Transformer T100 Front Panel Digitizer Replacement, Last step: step 12, image 2 of 2
      • The last step is to separate the plastic frame from the old Digitizer glass.
      • I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
      • You are now ready to put your new digitizer on the plastic frame and assemble the T-100.
      • BE VERY careful when applying heat to the plastic, it can easily bend so make sure you keep your heatgun/hairdryer on low heat.
      Ask FixBot
32 other people completed this guide.
Nick Johansen
2,039 Reputation
2 Guides authored
27 Guide Comments
Thanks so much for the guide, it was a long process but we'll worth it.
Cody Smith - Reply Share
Hope it was helpful and that it was detailed enough :) thank you for looking :)
Nick Johansen - Reply Share
Great guide, however I would make one small addition. In the final instructions just a little warning about keeping the heat very low, similar to a hair dryer and take your time. I discovered the hard way that the plastic bezel has quite a low melt/warp temp and I effectively ruined one of the two I was repairing. Sourcing a new digitizer with bezel or bezel alone is proving to be incredibly challenging.
adamstafford - Reply Share
Thank you for the heads up I will edit that as soon as possible
Please, can you give the clearer instructions about 3 different screw sizes, where are they locations. I mixed them up...
Lazeez Karshibayev - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 122
All Time: 36,750
