Introduction
This guide demonstrates how to replace the SSD in an Asus G16 (GU603VV) Laptop. SSDs can overheat and become corrupted if laptop vents are obstructed or the device is stored improperly.
If your laptop is frequently crashing or running slowly, replacing the SSD may help prevent data loss. You can also follow this guide if you're upgrading to a larger or faster SSD.
Before starting this repair, back up your important files and documents to an external hard drive or cloud storage. Unplug the power adapter and fully power off the device. Additionally, check that the new SSD is compatible with your laptop before installation.
Three M2 8 mm screws
Two M2 11.5 mm screws
Four M2 11 mm screws
Three M2 5.5 mm screws
One M2 8 mm captive screw
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
