Asus ROG G20CB Graphics Card Replacement
    1. Asus ROG G20CB Graphics Card Replacement, Fan: step 1, image 1 of 2 Asus ROG G20CB Graphics Card Replacement, Fan: step 1, image 2 of 2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      Ask FixBot
    2. Asus ROG G20CB Graphics Card Replacement: step 2, image 1 of 1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      Ask FixBot
    3. Asus ROG G20CB Graphics Card Replacement: step 3, image 1 of 1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      Ask FixBot
    4. Asus ROG G20CB Graphics Card Replacement: step 4, image 1 of 1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      Ask FixBot
    5. Asus ROG G20CB Graphics Card Replacement: step 5, image 1 of 1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      Ask FixBot
    6. Asus ROG G20CB Graphics Card Replacement: step 6, image 1 of 1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      Ask FixBot
    1. Asus ROG G20CB Graphics Card Replacement, Graphics Card: step 7, image 1 of 1
      • Remove the three 4.6 mm Phillips screws from the graphics card housing.
      Ask FixBot
    2. Asus ROG G20CB Graphics Card Replacement: step 8, image 1 of 1
      • Pull the graphics card housing out of the case.
      • Be mindful of the 8-pin power cable connected to the graphics card.
      Ask FixBot
    3. Asus ROG G20CB Graphics Card Replacement: step 9, image 1 of 1
      • Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
      Ask FixBot
    4. Asus ROG G20CB Graphics Card Replacement: step 10, image 1 of 1
      • Remove the 3.7 mm Phillips screw from the graphics card and its housing.
      Ask FixBot
    5. Asus ROG G20CB Graphics Card Replacement: step 11, image 1 of 1
      • Slide the graphics card out of the housing.
      Ask FixBot
    6. Asus ROG G20CB Graphics Card Replacement: step 12, image 1 of 1
      • Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
      • This riser will need to be used with the new graphics card in order to be installed in this system.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
AdamGadd
349 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 100
All Time: 776
