Asus ROG G20CB Fan Replacement
    1. Asus ROG G20CB Fan Replacement, Fan: step 1, image 1 of 2 Asus ROG G20CB Fan Replacement, Fan: step 1, image 2 of 2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      Ask FixBot
    2. Asus ROG G20CB Fan Replacement: step 2, image 1 of 1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      Ask FixBot
    3. Asus ROG G20CB Fan Replacement: step 3, image 1 of 1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      Ask FixBot
    4. Asus ROG G20CB Fan Replacement: step 4, image 1 of 1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      Ask FixBot
    5. Asus ROG G20CB Fan Replacement: step 5, image 1 of 1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      Ask FixBot
    6. Asus ROG G20CB Fan Replacement: step 6, image 1 of 1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
361 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 67
All Time: 365
